JoeH
Jul 11, 2020Explorer III
What Doug said----- I had an issue where the genset would die after a bit.... it was throwing a fuel pump code. After looking into things, I found that the battery cable that ran 40 ft or so from the chassis battery to the genset wasn't securely attached and would result in an open circuit thus shutting down the genset due to the fuel pump not operating.
See what code the genset is indicating and start our PD from there.
Good luck
Good luck
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
