LittleBill
Nov 18, 2021Explorer
sounds like the onan onboard fuel pump is dead. or if the definition of doesn't start means not crank. then on the board charging system is not working/powered and the batteries are going dead killing the fuel pump as well.
for those of you saying the onan has a charge circuit, it doesn't, at least not on the 4k onan.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
