Jdaniel343's avatar
Jdaniel343
Generator output voltage
I have a Kipor KGE 3000TI I bought used.
Generator runs my 13000 btu ac using 30amp plug. Also the 120v outlets will power equipment like a angle grinder just fine.
When I use multimeter to check voltage output at the outlets I'm only seeing 60 volts or so. Why is this?
  • theoldwizard1 wrote:
    Connect the generator to your RV. Turn on something inside. Test voltage at an outlet inside.
    That's what the OP said he did.
    I am not clear on that either. The OP's first post: "When I use multimeter to check voltage output at the outlets I'm only seeing 60 volts or so."
    OP, please verify you are checking voltage in one of the "house style" outlets in the RV-- and checking between the long straight (neutral) and short straight (hot) VS at the generator outlet.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
