PGCruisers's avatar
PGCruisers
Generator Overload
We recently traded the old '95 Sportsman for a '05 Cougar. The sportsman ran on two- 6 volt batteries, the new one has two 12 volt batteries. My problem is that my Honda 2000 ran everything fine on the old trailer, except the AC. First trip out with the new trailer and everything runs fine. Then with no additional draw the generator will ramp up to full throttle and overload. Right now we are boondocking and EVERY time I turn on the generator it shuts off.
My thoughts are that the inverter draws more power charging the two 12 volt batteries than the two 6 volt. Would going back to two 6 volts solve my problems?
Has anyone else had issues like this or can enlighten me to potential problems.
Mark and Tracy (Camping with limited power)
  • Need more input.
    You don't have your WH on electric do you? Perhaps by inverter you mean inverter/charger?. If you do have an IC the charge rate can be adjusted. The 2000 is capable of about 1800/13 = 138a of charging. That's a lot, and the genny would be screaming.
    Sounds like something else is on, or the 12v batteries are shot.
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 15, 2025
