mesoman7's avatar
mesoman7
Generator overloads with A/C
I know this topic has been beaten to death, but I am at a loss. My Champion 3100 immediately overloads when the a/c is turned on. The a/c unit is 13.5K BTU, so the gen should handle it. My older gen has a higher capacity. It would start up the compressor. After a minute or two, it would start to motorboat then trip the 30A breaker. I can run the a/c connected to the house on a 20A circuit with no problem. OK, to mitigate the normal questions:
Refer - off
Microwave - off
Water pump - off
Water heater (elec) - off
I even shut off the converter
What am I missing here?
- Jeff
  • Sounds like compressor or starting capacitor. Check your input voltages. Your house AC voltage is much better regulated for heavy loads than the generators.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
