JandKSunshine's avatar
Aug 24, 2017
Generator putting out 18 Hz?
Hello again! Man, I've been running down one problem after the next on this old generator we have. I finally got it running after a no-start and then a broken fuel line. Still need to fix the muffler. But now this:
I got the generator running and hooked up, with power going to the RV. It wouldn't run our AC, though, so I hooked up our surge protector that reads the voltage and frequency and all that.
It says 102 V, 18 Hz.
What could that possibly be? Maybe one side of the AC is dead? I checked the connections at the box, they look good. Could it be the brushes? I'm starting to wonder if I should just start budgeting for a new generator. lol
Again, your help is really appreciated. Thanks!
  • Gjac's avatar
    Gjac
    Explorer III
    Do you have a mechanical governor like on a lawn mower or a electronic governor board? On my Kohlar it has a governor board with a pot that can be adjusted to get the right hertz reading.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    It may be your meter.. Can you determine the rotational speed of the engine.
    It should be 3600/N RPM (iE 1200, 1800, or 3600 RPM) if so I'd suspect the meter
  • MrWizard wrote:
    i think your surge protector is out of whack
    18 hz just slightly above 1/5 of speed,
    is your generator really running at only 800 rpm ? normal speed is 3600rpm big big difference, way beyond { i think its running slow } more like "it barely runs and voltage is 50v"
    now IF one pole in the windings was dead (2) pole generator
    full speed would show 30hz and halve speed 1800 rpm would show 15hz
    yes vltage islow and speed probably needs adjustment
    just plug in a box fan or something and see how fast it turns or doesn't
    that will give you a working idea of whats going on
    Is it a 2 pole or 3? I thought they were 3 pole but don't know for sure. If 3 pole with corroded brushes, contacts I could see 18 HZ.
  • Cool, thanks, everyone! That definitely helps, I'll start looking at those tomorrow. I thought I posted the model, but I guess not. darsben1 got me, though, Thanks! It's a Onan Emerald Plus 4000 (GBE-k).
  • i think your surge protector is out of whack
  • Sounds like a governor issue. It regulates generator RPM to get you your 60 Hz. Depending on how old, could be mechanical or electronic.
  • I agree with naturist, it is probably running to slow, the 102 volts is low which gives a hint that it is slow, there should be a way to speed it up. not knowing the brand there is really no way to osmos the problem. Good luck and Happy Camping
  • I would not budget for a new genny. I would take it to a generator repair shop and have it gone over. The new ones are poorly built compared to the one you have.
    Even the new Cummins/Onans have really been cheapened up compared to what you have.
    But I think it may be the voltage regulator
    Go to flightsystems.com and find their troubleshooting guide. Notice they offer free technical support at certain times of the day
  • With no other details, one can only cast a wild guess. Mine: not running at proper speed, too slow.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
