alank2
Jul 15, 2016Explorer II
lc0338 - Do you turn off the fuel switch?
2oldman - It does, but it isn't much of a manual. It is a cheap 5kW style generator and isn't the easiest to work with.
joebedford - if the carb float is stuck, is there an easy way to unstick it without taking it apart?
There seems to be a two schools of thought on this! Counting up the "leave wets" and "run drys" is a 5 to 7 count.
I've been doing the leave wet and leaving the fuel switch on on my Yamaha, and it has worked for 7-8 years without trouble, but I am thinking about changing to either leave wet but turn off the switch, or turn off the switch and let it run itself dry.
Question #1 is - if you leave it wet and turn off the switch, will it dry up?
Question #2 is - if you turn off the fuel and run it until it stops, will the carb be completely dry? Or will there be gas left that could dry out and get gummy?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
