2oldman
Jul 15, 2016Explorer II
alank2 wrote:Ok, well, if what you've been doing is causing problems, then change it up. I think a dry carb is best. And I was causing fuel to get into the oil by inadvertently leaving the fuel (and ignition) switch on on my Honda 2k...according to a mechanic who cleaned the carb.
2oldman - It does, but it isn't much of a manual. It is a cheap 5kW style generator and isn't the easiest to work with.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
