Sam_Spade
Jul 15, 2016Explorer
alank2 wrote:
Question #1 is - if you leave it wet and turn off the switch, will it dry up?
Question #2 is - if you turn off the fuel and run it until it stops, will the carb be completely dry? Or will there be gas left that could dry out and get gummy?
Answer #1: Yes very likely, depending on how long it sits.
Answer #2: There will be a little left but it isn't a little that you are worried about. The problem occurs when some evaporates and is replaced by more which then evaporates and is replaced........
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
