westend
Jul 16, 2016Explorer
Drain or run the fuel bowl dry on the carb. Turn the fuel petcock/switch to "off". If the float is sticking or the engine is hard to start, remove the carburetor, clean it, and install. Observe the float relationship to the pin and hinge it uses. Rarely, but it does happen that the float will stick.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
