you are wanting to pair to make 240 volts? It would be easier to re-do the RV electrical system to run everything on one phase than to pair two different brands. The two need to put out the same current, and that is unlikely as stated above. The only paired.parallel I have seen are two identical gens that are factory made to be paired to the exact same gen.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
