countrykids's avatar
countrykids
Generator questions
We purchased a used class c this summer with built-in Generac generator. We used it several times and noticed the longer between uses the harder it is to start. The Generator was last run in mid October before today. I did get it started but not before I cranked it for 20 seconds or so. When it does start it runs great. Is that typical? It gets cold here mid winter and if slow starting now I wonder what will happen in January. Generator draws from the main fuel tank which has been stabilized.
I am doing this because other posts suggest it should be run several times during the off season. If so, how often, how long and does it need to be under some load?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
