time2roll wrote:
coolmom42 wrote:
How difficult is it to change out the converter? How is the wiring connected to the converter?
Five wires.
120v side is Hot, Neutral, Ground. Attach new same as you remove the old.
12v side is just Positive and Negative. Again connect same colors same as you remove.
Maybe a few screws to gain access removing the trim.
If it's a standalone (deck-mount) converter, there should also be a sixth bonding wire...but the AC connection is often a normal household plug, so it's three wires and a plug.
In any case, it's quite straightforward unless the replacement one is larger in some dimension than the old one or some other complication of that general sort comes up.
