enblethen
Mar 24, 2019Nomad
No offense but easier and less dollars to make your own.
Standard male cord body. Install wire between silver terminal and the green terminal.
Yes, it could be wired wrong. Look at genset, the larger slotted terminal is the neutral. Use a meter to test the cord body between these two terminals with it out of genset. There should be continuity.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
