TheHound
Mar 24, 2019Explorer
enblethen wrote:
No offense but easier and less dollars to make your own.
Standard male cord body. Install wire between silver terminal and the green terminal.
Yes, it could be wired wrong. Look at genset, the larger slotted terminal is the neutral. Use a meter to test the cord body between these two terminals with it out of genset. There should be continuity.
I appreciate the reply. Figured if I bought one made by Surge Guard, I would be good to go as I don't have much experience with this. I guess I will try and open it up and see how it is wired.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
