Bobbo
Mar 24, 2019Explorer III
Be sure it is wired GROUND pin to NEUTRAL pin. Nothing should touch the HOT pin.
Actually, to me it sounds like that bonding plug is wired GROUND to HOT. If it was wired HOT to NEUTRAL, it would blow the breaker on the generator.
Old-Biscuit wrote:
Jumper wire should go from GROUND Terminal to NEUTRAL Terminal
Sounds like jumper is on Hot to Neutral (defective plug/cross wired)??
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
