Old-Biscuit
Mar 24, 2019Explorer III
Bobbo wrote:
Be sure it is wired GROUND pin to NEUTRAL pin. Nothing should touch the HOT pin.Old-Biscuit wrote:
Jumper wire should go from GROUND Terminal to NEUTRAL Terminal
Sounds like jumper is on Hot to Neutral (defective plug/cross wired)??
Actually, to me it sounds like that bonding plug is wired GROUND to HOT. If it was wired HOT to NEUTRAL, it would blow the breaker on the generator.
OP stated
" With the bonding plug inserted it came back with HOT/NEU REV ..."
AC Reverse Polarity is Hot & Neutral being swapped.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
