TheHound
Mar 25, 2019Explorer
wnjj wrote:road-runner wrote:
When you test, are you using the twist-lock outlet on the generator? If you are that could help a bit with understanding things, and the info from DrewE, 5 posts above, could contain the answer.
That is precisely what happened in this case: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29758604/gotomsg/29762593.cfm#29762593
Wow, that definitely seems like the same issue including the different test results between the 20 amp and 30 amp plugs. With the bonding plug in, I get the "all is well" on the other 20 amp socket. When I put the tester on the 30 amp I get the HOT/NEU REV. The big difference is the OP in that thread knows what he is doing :( Appreciate you finding that.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
