road-runner
Mar 25, 2019Explorer III
wnjj wrote:And there's another current thread that could be the same thing:road-runner wrote:
When you test, are you using the twist-lock outlet on the generator? If you are that could help a bit with understanding things, and the info from DrewE, 5 posts above, could contain the answer.
That is precisely what happened in this case: http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29758604/gotomsg/29762593.cfm#29762593
Yamaha EF3000iSE neutral bonding issue
If it turns out that the duplex power terminals are wired opposite of the twistlock terminals with 3 different manufacturers that strikes me as more than a coincidence, and there must be some reason for it, right or wrong.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
