road-runner
Mar 25, 2019Explorer III
TheHound wrote:OK, then the post linked to by wnjj may very well be the answer. However, if the wiring diagram for your generator is correct you won't be able to find the answer by physical inspection because the duplex outlet and twistlock outlet are fed from different wires coming out of the inverter. I would first try to isolate this with an ohmmeter and the generator not running. With bonding plug out, check the resistance between case ground and both twistlock power terminals. Hopefully neither is close to zero ohms. Then insert the bonding plug and take the readings again. Hopefully one of them is close to zero ohms. The one that changed should be the designated neutral. There's a diagram for the twistlock outlet here:
Yes, used a twist lock and then 30 to 15 adapter so I could use my tester. Thanks!
Generator Connector L5-30
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
