TheHound
Mar 27, 2019Explorer
road-runner wrote:
Couldn't the incorrect wiring possibly be in the adapter? From pictures it looks to me like the neutral on the L5-30 is the narrower of the 2 power blades. That could make for an easy bad assumption when wiring either the generator or the adapter. Easy enough to check, just take the voltage readings at the twistlock instead of at the adapter.
Thanks for the suggestion. Pretty sure I checked at that point but will double back. Looking at the 30amp receptacle I am not entirely sure which slot is what. Could you advise?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
