TheHound
Mar 27, 2019Explorer
enblethen wrote:
You would need to look at your receptacle, but by this the neutral is the small blade on twist lock. Remove receptacle and see if the silver screw terminal goes to pin 2 on the inverter output terminal.
The one with the little hang nail is the ground.
L5-30 diagram
Thanks for the reply and the diagram. Typically, the smaller blade would be hot, correct?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
