wnjj
Mar 27, 2019Explorer II
TheHound wrote:wnjj wrote:
You can also consider swapping the hot and neutral on the 20A receptacle instead if the wires are easier to deal with.
Interesting. So as long as all receptacles are wired to the same post, it doesn't matter? Thanks
Correct. The generator has no hot & neutral, just AC output. One becomes "neutral" once it is bonded to ground.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
