enblethen
Mar 27, 2019Nomad
Yes, normally the larger blade is the neutral. Many gensets have no connection between neutral and ground. Wiring diagram shows pin 1 from inverter output has a circuit breaker in it. Typically this would indicate that pin 2 is the "floating neutral".
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
