TheHound
Mar 28, 2019Explorer
Well, I did the deed and will try my best to describe the wiring of these receptacles and hopefully the issue can be identified.
Unlike the pic from the other reverse polarity thread, my panel was a jungle of wires so I took a series of photos that may or may not be of use :R
Thanks a ton. Beer & pizza if you roll through Toronto!
30amp receptacle
- left side top post - SINGLE YELLOW WIRE w/ GREEN STRIPE (brass screw)
PIC 30A LEFT TOP
- left side bottom post - RED (goes to breaker) AND BLACK (brass screws)
PIC 30A LEFT BOTTOM
- right side - TWO WHITE WIRES ON SAME POST (silver screw)
PIC 30A RIGHT SIDE
20amp receptacle
- left side top - GREEN WIRE (silver screw)
- Left side middle - BLACK WIRE (silver screw)
PIC 20A LEFT TOP & MIDDLE
- left side back (corner) - YELLOW WIRE w/ GREEN STRIPE
PIC 20A LEFT BOTTOM
- right side top - WHITE WIRE (goes to parallel plug) (brass screw)
- right side bottom - GREEN WIRE (brass screw)
PIC 20A RIGHT SIDE
30amp receptacle
PIC 30A LEFT TOP
PIC 30A LEFT BOTTOM
PIC 30A RIGHT SIDE
20amp receptacle
PIC 20A LEFT BOTTOM
PIC 20A RIGHT SIDE
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
