wnjj
Mar 28, 2019Explorer II
TheHound wrote:wnjj wrote:
Pic 6 looks like the white wires are on the correct neutral pin on the 30A (right pin when looking at the front of the gen). Then from there, I can't quite tell but it looks like one of those exact wires heads over to the right side of the 20A which is supposed to be HOT.
In summary, the right side of the 30A should connect to the left side of the 20A (white) and the lower left of the 30A should connect to the right side of the 20A (black).
The green and green/yellow wires are fine as they are.
Thank you. Now let's see if I have this correct :)
TO DO:
- disconnect black wire from left side of 20 amp which is below the green wire
- disconnect white wire from right side of the 20amp and reconnect to the left side of the 20 amp where the black wire was
- connect black wire to right side of 20 amp where the white one was.
- leave red wire and green/yellow wires as they are
How am I doing? lol
Looks great. Hopefully there's enough slack to do that.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
