wnjj
Mar 29, 2019Explorer II
TheHound wrote:wnjj wrote:
Looks great. Hopefully there's enough slack to do that.
Your sir are a ***bleeping*** genius lol!
SUCCESS!
This has been quite the learning process and I thank everyone that has piped in so far :) But one more question, sorry.
I noticed now I am getting voltage readings on all receptacles ONLY between hot and neutral. I thought I should also see it between hot and ground. :? Which is correct? Cheers! -Frank
Excellent! Good work getting in there and getting your fingers dirty.
The ground on your generator is only connected between the ground pins of the receptacles, the ground lug and possibly any metal in the chassis. Until you plug your bonding plug it, there will be no potential between it and anything else. After bonding it you should see 120V between ground and hot on all receptacles.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
