TheHound's avatar
TheHound
Generator/ Reverse Polarity Question
Hey folks,
My knowledge on these matters is marginal at best so I am hoping someone here might have some suggestions regarding this issue I encountered today.
I went to test my shiny new Surge Guard 34930 with my 3200 watt inverter genny (using a Surge Guard bonding plug) but I am getting a reverse polarity message and it will not pass power through.
To check further, I bought a 30m to 15f adapter and then plugged in my tester. With the bonding plug inserted it came back with HOT/NEU REV based on the little legend thingy.
When I remove the bonding plug, I get just the middle light (open ground) which I understand is normal with inverter generators.
Very puzzled as all my research said the bonding plug corrects this issue and allows for the use of a SP. Any thoughts? :) Thanks!
  • I have an older Surge Guard that works fine (It has GFCI) with a floating neutral inverter gen. Why do you need or want the bonding plug? I know the PD's EMS one needs the bonding plug from what guys on here have said.
  • Jumper wire should go from GROUND Terminal to NEUTRAL Terminal
    Sounds like jumper is on Hot to Neutral (defective plug/cross wired)??
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 09, 2025
