mustard's avatar
mustard
Generator RF Noise
I just installed a Cobra handheld CB with a firestick antenna behind the left driver's window.
I've notice a very large amount of RF noise when running the generator.
Anyone experience this and can tell me how can I eliminate the RF Noise?
  • With an inverter (not a generator) the idea was to use a "chassis ground" to the RV frame, separate from the input DC pos and neg wires from the battery (but battery is itself neg grounded to frame--never mind that!)
    Another trick is/was to braid the pos and neg input wiree to the inverter to cancel out their effects.
    So--with the generator running 120v in the rig to run the CB radio, what is the actual set-up? Is there an inverter involved? Any DC where you can braid the pos and neg wires? The radio must be DC? Is it grounded to frame?
  • A Faraday shield could help, but a good ground connection woouldn't hurt, either.
  • I am no electical engineer but I'd think about building a rough Faraday cage out of metal window screen, the fine mesh stuff not hardware cloth.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
