Winnipeg
Jul 22, 2017Explorer
We had a similar problem with a 5ver a few years ago. The gen would run for 20 minutes and then shut down. It would re-start after some cranking and then shut down again in 20 minutes.
After much searching, we found that we had a bad check valve at the fuel tank (located about 30' from the gen). There was enough fuel in the line to run for 20 minutes, then it would get air.
A somewhat easy test it to disconnect the fuel line and run a temporary line to a fuel can. If it runs OK with the substitute fuel supply, then you have located the problem.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
