Romer1's avatar
Romer1
Generator runs 30 minutes, shuts off
My Onan NHE 6500 just started with this problem. Starts fine and will run for 30 minutes with a/c on. Shuts off and will restart if I wait about 3 minutes and runs for another 30 or so minutes. If I try to start it before the 3 minutes, starter cranks but engine won't catch. Gas tank is over 3/4, oil is full, new air cleaner, so I'm at a loss.
  • Romer1 wrote:
    gbopp wrote:
    Oil level in the generator correct? When did you chamge the generator fuel filter?
    Do the simple things first.
    Yes and fuel filter changed 9/14, about 250 hours ago
    @60 mph 250 hrs would equal 15,000 miles.
  • Romer1 wrote:
    w4phj wrote:
    Possibly the oil is thinning out and reducing the oil pressure enough to trip off the generator engine. You may want to try 10W30.
    But 2 -3 minutes wouldn't be enough for oil to cool that much that it would run another 30, would it?
    Saw it happen before. Bad oil. Easy to fix.
  • Possibly the oil is thinning out and reducing the oil pressure enough to trip off the generator engine. You may want to try 10W30.
  • Oil level in the generator correct? When did you chamge the generator fuel filter?
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
