John___Angela
Feb 25, 2016Explorer
Well if you you are running your fridge on auto you are adding a heck of a load as it will see 110 volts when the inverter is on unless you have a transfer switch to take it out of the circuit. Switch it to propane. Not auto.
Unless it is a danfoss type compressor cooler the cooler is definetly sucking up power as well.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
