time2roll
Feb 25, 2016Nomad
Fridge will pull 30+ amps from the battery. This is your main culprit for discharging the battery. Need to switch to propane only.
You need four hours of 14.1 volts to be close to full on the battery.
Yes try the air again will ALL breakers off except main & air.
You really needed just 150w to 300w inverter to run the tv especially having just two batteries. You would know immediately when you turned something too big on as a small inverter would just shut down.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
