STBRetired
Aug 11, 2019Explorer
If the house batteries get run down, the generator will stop. It requires 12V o run the control circuitry. The generator itself will not charge the batteries. It needs the converter or an inverter/charger to do that.
The generator shutting off should not hurt the A/C units. Now, if the generator was surging or the power was cycling on and off quickly, then the A/C might be damaged. Usually the damage would result in no cooling (as in burned out compressor) as opposed to reduced cooling.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
