mikemc53's avatar
mikemc53
Explorer II
Dec 22, 2019
generator surge
Onan 5500 in our Class A had run quite well last fall on our way down to Florida. Since arriving and storing the unit it has run well, when it gets used (about every two weeks to keep it fresh), but It does sit more than normal. Earlier this week I was running it and after starting and running for a few minutes it started to surge. I was running a fairly light load (a heater) but it surged regardless of whether I ran the heater or not.
I pulled the air cleaner while it was running and played with the choke plate. When fully open it surges but when I close the choke (partially or almost full) it runs much better. Is it running lean? What should I check or do before getting too deep into this?
Thanks gang.
