TFin04 wrote:
pianotuna wrote:
Equip all three rv's with hybrid load support inverter/chargers.
Acquire a 6000 watt inverter generator.
I would pick a champion.
Alternately get two Predator 3500 watt generators. They can be combined together to provide power to the RV's.
6000w is enough to power all three? Interesting, I was thinking it would take more than that.
6Kw across 3 RVs (two which have 50A capability) is not going to cut it in the middle of summer with A/Cs running full tilt.
Would need closer to 9Kw minimum to be able to support all three with only one A/C running per RV.
Rather than attempting to pool power from one super large gen you will be better off with each RV bringing and using their own gen.
The larger gen you are running, the more fuel you will use under light loads. Larger gens are much more louder than the smaller compact inverter style gens. Not to mention everyone will be depending on one single gen, when it runs out of fuel, shuts down or fails the entire group is affected.
