Is the best way to use a Honda 1000 generator to just plug the trailer cord into it? Or, should I use a battery charger and go directly to the battery? Would the answer be the same for a Honda E...
Best shot with a Honda 1000 is 40 amps and ~14.4 volts. Portable I recommend the Black and Decker 40 amp. We don't know your converter to compare. EM500 you may need to run that B&D at 20 amps.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
