Is the best way to use a Honda 1000 generator to just plug the trailer cord into it? Or, should I use a battery charger and go directly to the battery? Would the answer be the same for a Honda E...
Plug shorepower cord directly to generator utilizing your onboard converter for battery charging since charging circuits contained within many generators are woefully inadequate. It appears your rig has a WFCO converter that has the issue of not going into bulk charging mode, a black & decker 40 amp smart-charger would be a good investment and could be used in conjunction with your converter to dramatically speed up the charging process.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
