RoyB
Jul 31, 2015Explorer III
You may however end up with various GFCI faults when using the GENERATORs and OPTIONAL INVERTERs in your particular trailer wiring setup.
I have a 1500WATT PSW INVERTER here that when I plug the trailer Shore Power Cable using a RV30A-15A Adapter cable into its 120VAC receptacle I trip some GFCI receptacles in the trailer. The fix of course is to BOND the 120VAC receptacle on the OPTIONAL INVERTER front panel. I have another 600WATT OPTIONAL PSW INVERTER from the same manufacturer that does not trip any of my trailer GFCI circuits (Go figure)...
This may also happen in some trailers when you plug the shore power cable using a RV30A-15A adapter cable directly into the generator 120VAC receptacle.
If you are not experiencing any of these GFCI faults I would not BOND the Generator or Optional INVERTER...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
