enblethen
Apr 28, 2015Nomad
The two switches are then paralleled to the circuit board in the genset.
The remote wires go into the circuit board, then should operate a small control relay. You need to check the common point on the switches for 12 volts DC power.
If no power is present it will not operate. That is when the fuse, at least on mine, comes into the equation.
