Empty_Nest__Soo
Jan 22, 2015Explorer
Our 1997 Safari Sahara has a Heart Freedom inverter/charger with the wall-mounted remote inside the coach. Choices are “off” and “on” via a rocker switch on the remote. In reading over the manual after our purchase last summer, I found that one of the DIP switches on the back of the remote controls battery charging – one position is “charge when the inverter is turned on,” the other position is “charge continuously.”
I found mine was set to the “charge when the inverter is turned on” position by the previous owner. He also installed two BatteryMinders to maintain the fully charged battery banks instead of relying on the inverter.
Makes perfect sense to me. I turn the inverter on when I’m off-grid or when I choose to charge through the inverter, otherwise I usually leave the inverter off when hooked to shore power.
Wayne
Wayne
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
