ZZSPIRAL1's avatar
ZZSPIRAL1
Generators and charging RV batteries - Questions/Comments
I'm seeking an education on generators. First off, I have a new Yamaha 2000IS. It's great, but I do have some questions. I have one battery 85 ah battery, and will eventually get a bigger one. I don't use the A/C.
1. What's a general rule of thumb for the time it takes to recharge a battery? I realize it depends on how low the battery is, but lets say the generator is used every day to replinish 30 amps, and then 70 amps.
2. These generators have the economy switch of some sort. Do you agree it's better to not use this switch if the intention is to watch TV and charge the battery?
3. In your opinion, is a 1000W generator inadequate for charging a battery? Seems they're perfect for most appliances, but they may not be practical for charging batteries also.
4. And finally, maybe it's fairly simple. The 1000W generator produces 7.5-8.3 amps, while the 2000W generator produces 13.3-16.7 amps. If 70 ah are being used in a day, then is it safe to assume that the 1000w generator would have to run for about 9 hrs per day, while the 2000w generator would have to run for about 5 hrs?
Thank you for you input..........Note....I'm beginning to realize a good way to do things is a solar panel and a generator. I could probably get by with a 1000w generator and a 100W panel. My problem is battery bank. I can't fit more than two small batteries or one large one. I'll probably get one large one.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
