MEXICOWANDERER
Mar 17, 2016Explorer
Living at 9,000 ft, I tuned an around-town service truck to run as best it could.
Like my LPG pickup it took 12.5 - 1 pistons, a Crower Camshaft with high lift rather short duration and little overlap. one and one half degrees ********. A modified HEI distributor, with 30 degrees mechanical advance and fourteen initial. I hate Holley carburetors, but I used a 390 CFM, re-jetted and with 4.5 power valve. Simply rejetting the original engine didn't do snot except gain a tiny fraction of gas mileage. The truck hauled a 6-7 Detroit prime mover and 60 Kw Lima generator and a filled 260 gallon diesel tank to 11,200 feet without complaint. The cooling system was filled and the engine had 6 gallons of oil in it. I did not dare take the truck to <4K ft altitude. I sold it, as a matter of fact, in Mammoth, to a local "rancher" as a farm utility truck.
*********censored. Oops I meant to write the camshaft as being installed timed at mentally developed challenged one and a half degrees. Ever play in Reno or Vegas at a "Mentally Developed Challenged" table? Whatever you do don't bet on "The Field"
As an FAA PMA my experiences occurred on the ground. I heard so many different pilot "opinions" about "tweaking" fuel mixtures I grew deaf to comments. I specialized in Continental and Lycoming electrical, engine starter motors, alternators, and OVL systems.
Re-jetting a low compression engine for high altitude is about as worthwhile as polishing the finish for better mileage. It just wasn't worth it not even close. I did shave the cylinder heads on a Witte diesel about .200" to raise compression at 9,800 ft and that worked -way- better than throwing a new pill in the injector system to lean it out. Sticking a turbo on works best.
If it won't work, buy a bigger gen or a brand known to work at the altitude you camp at, is my recommendation.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
