- road-runnerExplorer III
Jetting just trims the fuel to match the lower volume of available air at higher altitude. It will not gain you any power unless it is running so rich it will not run well. In that case, jetting will only get you to the point that Chum Lee mentions above.
I think anybody who flies a gasoline powered airplane will disagree with this statement. The rich mixture engine runs smoothly at high altitudes, and has a very noticeable power increase when the mixture is leaned out. As would be expected, fuel consumption also goes down. - rving4usExplorerThanks everyone, I have a 3500/4000 champion,but it is a little loud. What every I decide it will not be used much Just will be staying in a couple rv parks with no power and I use a CPAP machine. Don't think the batteries will last running it.
Thanks again. - CJW8Explorer
I am a licensed pilot and have worked on small engines all my life. When a pilot leans the mixture as he gains altitude, he only gains a small but noticeable amount of power because he is getting the mixture right for the altitude. That power will still be less than he would have at a lower altitude with the proper mixture. - loggenrockExplorerOK, the Rockies I can understand... A LOT of where we visited in AK is at sea level, so no issue there...! ST
- JiminDenverExplorer III am a RC pilot and if I were to take one of my planes tuned at 5000 ft and try to fly it at 10,000 ft, it wouldn't run worth a dang. The adjustment isn't much, the advantage is huge. You would be surprised how much more power you have to hang on the front to get the same as you would at sea level.
Also running a generator rich will foul the plug and clog the spark arrestor faster. Champions high altitude jet is only good for 3000 ft unless they changed something.
I live high altitude, I camp twice that. Been there, done that. ;) - Chum_leeExplorerAll good points above. I am a licensed pilot too and have worked on many different engines with carburetors and/or fuel injection for years. We are a little off topic, but the purpose for running an engine rich at high power settings (like on take off in an airplane or at maximum load in a generator) is to reduce cylinder head, exhaust valve, and exhaust gas temperatures. It also cools the intake charge when the excess fuel evaporates (but does not burn because of lack of oxygen) reducing the possibility for detonation. It can eventually foul spark plugs, build combustion chamber deposits, and, dilute the engine oil with fuel if done too often and for too long. It also slightly slows the flame speed in the combustion chamber.
To be clear to the originals posters question, yes, you could tune most generators to operate at altitude, but, don't expect them to perform at the specifications the manufacturers publish for operation at sea level and standard conditions. (29.92 inches Hg, 59 degrees F, and low humidity)
Chum lee - Kayteg1Explorer IIWell... I drove my 32' Bounder with old carburated engine over 12,000' without any modification.
Sure on curvy mountain roads I did not use full power.
They were no boat engine modifications available at Lake Tahoe neither. - road-runnerExplorer III
CJW8 wrote:
I didn't mean to say that one could get MSL power at altitude by leaning the mixture. I do feel like the amount of power gained with leaning the mixture is more than small. Taking off from Denver in a loaded 172 with the mixture full rich will leave you sweating bullets as the runway end approaches and you're still on the ground.
I am a licensed pilot and have worked on small engines all my life. When a pilot leans the mixture as he gains altitude, he only gains a small but noticeable amount of power because he is getting the mixture right for the altitude. That power will still be less than he would have at a lower altitude with the proper mixture. - joshuajimExplorer IILicensed pilot here too. Leaning the powerplant at altitude DOES NOT increase power, it reduces power loss due to incorrest stoichiometric ratio.
- SkiSmuggsExplorer
Thanks again.
Most CPAPs run at 12V with the power brick converting from 110v. I ordered 12v cables for both my CPAPs and they use very little battery during the night running direct from a 12v outlet instead of having the overhead of an inverter. Installed a 12 receptacle on my head board using the reading light wires.
Also, there are high altitude jets for the Yamaha M80 engine.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
