j-d
Aug 06, 2017Explorer II
Ralph Cramden wrote:
I'd bet he's on his way over to the parking lot sale at Hazard Fraught Tools to pick up a 12hp 4500 watt noise and fume generator.
We have an onboard ONAN 4KW in the coach, so RV generator's not much of a priority. Being able to use the RV genset to power the house... now that could be. At a minimum, I should install a 30A "Buddy Outlet" so I could use RV extension cords to bring power into the house.
But a remark about the Open Frame gensets got me thinking. Some of us have 220 VAC equipment that would be good to be able to run on a genset, and the bigger open frames will usually allow that. Inverter gensets, and constant speed ones like our ONAN, will not. It isn't enough to say "It can't run the Central A/C, so no need for 220." Now when there could be pumps, etc. the 220 option should be considered.
Then recently, a 220 unit could be connected to both 110 legs of a house breaker panel WITH PROPER DISCONNECTION FROM THE GRID!!! Still couldn't heat water or run A/C, but way better than having only half the light switches in the house dead...
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
