westend
Jul 22, 2014Explorer
The best venting will come with a continuous ridge vent. I like the GAF spun material rather than the formed plastic vents. The formed plastic vents tend to deform from the intense heat. If you use the spun material vent, you'll need to either buy ridge covers or form your own out of metal (assumes you have a metal roof). The ridge vent is installed after 1 1/2" of roof sheathing on each side of the ridge is cut from the peak. A 40' piece of continuous ridge vent is equivalent to more than a dozen fixed vents.
White roof spray is also a good idea. I applied elastomeric roof coating to my trailer with a conventional Graco airless sprayer.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
