cruz-in's avatar
cruz-in
Getting Wire into frige?
Hi Team,
Tomorrow I will be installing two fans in the refrigerator. I need to run wires from my fan controller (located outside the refrigerator) to the fans (inside the refrigerator).
Any thoughts on how to run the wires from outside to inside of the frig?
Thanks
Dan
  • If your running 12 volt fans inside fridge just use the inside light for your 12 volt power no need to make holes. On my Dometic I just hook the poss. wire to the light door switch and the neg.(ground) to the neg. on the light switch. My fan runs when the light is off and turns off when the light comes on. If you want you can add a on/off switch in the fan. For the outside fan you have 12 volt power on the back of the refrigerator.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
