BFL13 wrote:
The GCFI "does not need a ground to function", but if you have a GFCI popping, ISTR you can stop that by snipping your shore cord's ground prong. (Not a good idea!)
How can both of those things be true?
Confusing to me also. I can see a non grounded GFCI functioning in a sticks and bricks built structure where there can be alternate paths to ground. Metal plumbing would obviously provide a path. But if an RV has an ungrounded frame sitting on rubber tires and wood/plastic blocks, how can you have a ground fault? For a ground fault to occur, there must be some path to ground for the stray current to drain off causing the current differential between hot and neutral.
Educate me.
