Harvard wrote:
Given: A 120 VAC GFCI supplying power to a 30 AMP RV. The RV has one problem, the 3rd Prong Ground wire at the 30 AMP plug is not making connection. (The RV chassis is floating because there are no other sources for a ground conduction path.)
Q: Will the GFCI trip because of this "one and only problem", an open ground?
I am guessing NOT.
I thought the RV shore cord plug's ground operated from the ground it gets from the bonded panel the RV is plugged into, where the RV is like an appliance. I get two lights (normal) with the three light tester when plugged in, not an open ground.
When I had a GFCI problem in the RV popping the RV's own GFCI receptacle, I checked if it was fixed after finding the problem in the RV, by plugging the RV, via 30/15 and extension cord, into the house bathroom GFCI receptacle. That house bathroom GFCI popped when the RV still had the problem, but did not pop afterwards,
. I did not check the three light tester in the RV when I was plugged into the house bathroom GFCI receptacle when the bathroom GFCI and the RV GFCI was not popped after that got fixed. ( I would expect to see the two yellows same as with a non-GFCI receptacle)
Not convenient right now to run a cord into the house bathroom and see what the three-light tester does in the RV
EDIT-- Did that. Got the two yellows per normal--no "open ground"
