Harvard's avatar
Harvard
GFCI and an Open Ground
Given: A 120 VAC GFCI supplying power to a 30 AMP RV. The RV has one problem, the 3rd Prong Ground wire at the 30 AMP plug is not making connection. (The RV chassis is floating because there are no other sources for a ground conduction path.)
Q: Will the GFCI trip because of this "one and only problem", an open ground?
I am guessing NOT.
  • road-runner wrote:
    I would think that detection of a downstream neutral-to-ground fault would be lost.
    well considering neutral and ground are tied together at the panel, it would be considered faulted 100% of the time
  • I would think that detection of a downstream neutral-to-ground fault would be lost.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
